View the thread, titled "Backfeeding through a newly fitted shower" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
K
Kirsty
I have an unvented hot water system.
Following a recently fitted shower I noticed our hot water all over the house was coming out tepid--->hot.The worst taps are those nearest to the shower. I cannot use the shower yet because the water won't come out hot enough!
British Gas came out today and diagnosed back feeding through the new shower.The elbow to the hot supply of the shower goes immediately cold when you turn off the shower and then run the sink tap. If I run the shower I can get hot water from the sink tap! Is this a faulty shower with a dodgy non return valve or can it be fixed by reducing the cold water pressure??
I am assuming the hot and cold water supplies should be at similar pressures. Is there a risk to the hot water cylinder if the cold is back feeding to the tank--I note that those that have had a similar problem in a gravity fed system have had header tanks overflowing! I have no way of isolating the cold supply to the shower!
Any advice appreciated!
The plumber is coming back on Monday to look at the shower mixer.
sounds like no non return valves were fitted, OR if they are the type that come pre installed in the elbows (bristan do this on some of their models) then it is faulty non return valves. has it done it since day one?
Thanks for the fast replies:
I don't know if it is after the pressure reducing valve.The old shower was taken off--this worked fine and the new one fitted--after tiles taken off to get to the pipes!
Maybe the old shower had non return valves in the elbows., it was a Combi HP Triton.I think the new one is a triton too---plumber tried not to have to take off tiles--just refix but the new on couldn't be fitted without more destruction first.
Yes it's done it since day one--not used the shower yet as I thought it was our hot water system and I wanted to get it checked for the plumber first. It's obviously a shower problem causing the hot water problem though.
The plumber was looking at fitting one of these--should it be necessary in an unvented system.The hot water is pressurised. Are non return valves needed as well?
The cold is not balanced properly rather than non return valves you need a pressure reducing valve of the same pressure on the incoming main. When I do unvented i always do that.
By doing this you will mitigate against future problems with mixer taps etc.
Reply to the thread, titled "Backfeeding through a newly fitted shower" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
