E
Engeroosi
I have a foul smell coming from under my floor but have no blocked drains, anyone have any idea what this could be?
fraid rats cr*p everywhere , much like mice, they arent "clean" and favour one place to pooh. If you have rats you will have evidence of nests etc that can smell overpoweringly of urea, however if you have damp under your floors you can get dry rot that has a fairly distinctive odour of rotting wood. If its your ground floor smelling check the airvents are clear around the house and they arent blocked as this can cause woodrot if there is no fresh air moving around and hence a smellWell no the smell from a dead rat or mouse only lasts up to a week
You could have an open or cracked drain but usually drains smell but would not say overwheling ,or you may have a rat toilet under the floor
Mice are incontinent and boo all over ,rats use one place and this could be under your floor,if so you are better getting pest control in,you do not want to be rummaging through their excrement as very dangerous 🙁
dear plumbers forum does anyone know how to get rid of the smell of jeyes fluid ?since i put it under my floor boards the house smells like a festival toiletJeyes Fluid
Hire a steam cleaner and do it properly then.
Iodophor disinfectant is quite good at getting rid of smells and doesn't smell much itself (Iodel FD). Works a treat on the dog kennels, which can get quite niffy at the best of times!
Reply to the thread, titled "Bad smell" which is posted in UK Plumbers Forums on Plumbers Forums.
