View the thread, titled "Bad toilet hammer" which is posted in Boiler Advice Forum on UK Plumbers Forums.
N
nzmanc
Every time I flush the toilet there is a real awful hammer. We have a bottom feed torbeck fitted. Can anyone recommend a better float valve?
I think the best on the market are Fluidmaster Pro45B.
Not sure if they are the best, but I've been told that and fit them out of choice myself. Fast, quiet filling and they have a brass shank.
Its not your cistern ball valve that's at fault, it's the one in your storage tank in the loft, assuming you are indirect (tank fed)
Replace the brass 15mm ball valve in the storage tank, if it still happens, ask the plumbers merchants for an equilibrium ball valve.
It is normally caused by a fluctuation in pressure, and or, a poorly seated diaphram...........change it.
The problem was quite a simple one to fix. Id moved in and opened the stop tap fully. Turned it another half closed and its fine now. The only problem now is finding the right balance as the electric shower cuts out if the pressure drops.
Is there a service valve (eg a screwdriver operated one) just before your cistern? If there is you can partially close it to get the same result without effecting other parts of your system, if there isn't might be worth getting one put in to do this (+ water regs state you need one).
make sure pipes are well clipped and also if two pipes are knocking together can also cause hammer
Reply to the thread, titled "Bad toilet hammer" which is posted in Boiler Advice Forum on Electricians Forums.
