View the thread, titled "Baffling condensate pump problem" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Paul_A
Hi
4 years’ ago I had a Worcester Bosch Greenstar Ri boiler installed. Due to its location, a Sauermann condensate-removal pump was also fitted. For the first three years, no problems, but then the pump began to operate every few minutes whether the boiler was operating or not. I have an engineering background so had no problem discovering the pump's non-return valve was faulty, i.e. it was leaking. I contacted Sauermann who initially were very helpful. I was told the valves do fail every few years, which is fair enough, so I ordered a replacement and a spare for the future.
After 3 months, the new valve failed. I fitted the spare and that too failed in a couple of months or so. I contacted Sauermann again who implied that there is a rare but known problem when their pumps are installed with the Worcester Bosch model we have. Their solution is to install their pH Safe device which fits in-line with the valve to filter out whatever they think it is causing the problem. Sadly, that device does not fit the pump I have, and they don't offer one that does.
I contacted Worcester Bosch and I wasn't surprised that they had no idea what Sauermann were on about but would investigate if they had specific details. I have tried all ways to get Sauermann to give me more information, even writing a ‘proper’ letter to the MD. Nothing!
I have found that if I immerse the faulty valve in water for a few days it will eventually return to a working state, although only for a few weeks. So this is where I now am – swapping the valves as and when they fail, which is fairly useless if the house is to be left unattended for a long spell during cold weather. I have recently had the boiler serviced by a Gas Safe engineer who found nothing untoward whatsoever. A relative had the same pump installed with a WB boiler at around the same time, albeit their's is a combi boiler, whereas mine isn’t. They have had no problems.
Can ANYBODY tell me why this problem did not arise for 3 years but is now a permanent feature? I’d be really grateful for any help.
Thanks, Paul
Im thinking its to do with the rubber compound used in the NRV which has been effected by the acidic solution from the boiler but then Im a pump man not a plumber
In a pump designed to remove condensate.........
fair point croppie but It was just an idea and I`ve never heard of that pump but have seen wrong pumps installed in wrong situations.
I know, made me smile is all :smilewinkgrin:
I've noticed that Worcesters seem to have a lot of debris in their condense trap compared with other boilers, I wonder if some of this is making its way into the NRV and knackering it?
Thanks for all the replies. Having asked for advice, I am loathe to disregard it, coming as it does from those that actually work in the industry. Here are my thoughts though.
The condense trap was checked for debris - there was none.
I have considered that a new pump might solve it, and if I thought it
definitely would, I would replace it. Because I've discounted the NRV itself, that would imply that something in the pump mechanism is malfunctioning, and with my electro-mechanical engineering background, I cannot see how that in itself could possibly produce a substance that would affect the NRV.
Many thanks anyway.
Reply to the thread, titled "Baffling condensate pump problem" which is posted in UK Plumbers Forums on Plumbers Forums.
