View the thread, titled "Balancing Query" which is posted in UK Plumbers Forums on UK Plumbers Forums.
T
thirl1804
Hello
I need some advice regarding my central heating pump and a balancing issue I have.
My house was built in 1999 (4 bed detached) and has a microbore central heating system throughout. Recently, I removed a radiator downstairs to paint behind it, when doing this I cracked one of the joints and it began to slowly leak. To fix this I drained the system and patched up the leak OK.
However, since this I have had a problem with balancing the system. I believe these microbore systems use manifolds rather than daisy chaining the rads so I’m looking for general information regarding this.
The problem is that I have to have my CH pump on its highest setting to get any water downstairs. Anything other than the highest setting results in just the upstairs rads getting hot water.
I have two queries which I’d appreciate comments on. Is it bad to constantly run your CH pump on its highest setting? There is a fair amount of vibration and noise from the pump.
My second request is can anyone point me to any documentation/links to explain how these manifolds are normally situated in a house as this may give me some idea of how to balance the system better.
Thanks in advance for any comments regarding this.
Reply to the thread, titled "Balancing Query" which is posted in UK Plumbers Forums on Electricians Forums.
