View the thread, titled "Bar shower thread extensions." which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
Chalked
When you have installed backplate elbows for a bar shower, what does everyone use to extend the female connections to the cranked adapters.
Happens a lot when thick tiles are used.
i normally use 1/2 FI x 15 mm compression fittings ptfe these in.the trouble is they are parallel thread so don't tighten in too well.
been to a job of mine today where this had been leaking a while and I've had to re plaster and replace tiles. So looking to find a better option.
it would be better if manufacturers made the 1/2 thread longer.
Better to buy the quick fix kits. About 25 quid in toolstation.
I hate the hidden threaded joints. Better to have soldered elbow in wall and then external fixings
Reply to the thread, titled "Bar shower thread extensions." which is posted in Showers and Wetrooms Advice on Plumbers Forums.
