View the thread, titled "Basin mixer, high cold pressure, 0.5 bar hot (gravity HWS)" which is posted in UK Plumbers Forums on UK Plumbers Forums.
JCplumb
Got a customer who has called me in after an absolute nightmare with a cowboy builder and an ex-friend project managing her renovation.
I feel really sorry for her, she was actually crying when explaining what had gone on when I first went round.
Anyway, she has a basin mixer that she really would like to use, unfortunately her hot water is on gravity and her cold water could strip the skin off your hands. My first piece of advice was that 2 seperate taps are needed.
I put my hand over the spout of her kitchen tap and opened the cold up and could hardly stop the flow, didn't test the pressure but it's very 'good'.
The cowboy builder has literally ripped off for thousands of pounds so I'm going to try and get the tap to work.
It's a square handled waterfall type tap and Joyou do one that would be perfect as it is designed for use on all water systems but I can't find anywhere with one in stock.
Anyone had any success with gate valves or other forms of ISO's in getting the cold flow low enough for a blender type tap to work on such a system? Obviously I'll be fitting an NRV on the hot pipework and I know that limiting the flow won't limit the pressure, but would love to try and sort this for her as easily(and cheaply) as possible.
15mm pressure reducing valve.
http://www.NoLinkingToThis/p/honeywell-15mm-x-pressure-reducing-valve-with-gauge/7978j
Cheers for that, already looked into it, it will take it down to 1.5 bar so will still be overpowering the hot 🙁
There are others as I have seen them used for tmvs hot gravity and cold mains
Yeah, I tried to have a look round last night and made a few calls today but not much that will take the pressure down to less than 1 bar. They exist but you don't half pay for them from the ones I saw.
Could I manage it with a gate valve? Get the cold flow down low enough to allow room for the low pressure hot to come out of the tap ?
No
533841
Will do lower than 1 bar
Also Google deva pev002
Did the job today, was delayed by a joiner who needed to make the bespoke cloakroom furniture first...
Started with the cheapest option of using an ISO to reduce flow on the cold with a non-return valve on the hot.
It worked a treat.
I was expecting that I'd have to go back with a reducer or pressure equalising valve, but it worked surprisingly well with just an ISO to slow the cold down.
Happy days 🙂
Reply to the thread, titled "Basin mixer, high cold pressure, 0.5 bar hot (gravity HWS)" which is posted in UK Plumbers Forums on Electricians Forums.
