View the thread, titled "Bath Shower Mixer Tap Leaking from lever" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
dtpevans
Hi all...
Please see picture below..
Our bath shower mixer tap is leaking through the lever/handle to switch between bath and shower.
So when you turn on the taps water leaks from the lever - on both cold and hot taps.
In shower mode it is fine.
Has anyone got any ideas how to fix this..i.e. can you remove the lever on it's own
Hope this makes sense and any advice much appreciated.. Dave
Tom - thanks very much - I have screwed the knob of (see pic below)...does it need a washer here or inside the unit..apols for stupid question..
If I need to get inside not sure how I can do it, i took off the hose on the bottom but it looks like its all part of the main unit..photo (34).jpg
thanks not sure of make - builder put it in!
got a bad feeling a new tap is needed and if so will need to move bath?
I can see a way to take out tap cartridges but not a way to take out lever..
Reply to the thread, titled "Bath Shower Mixer Tap Leaking from lever" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
