View the thread, titled "bath/shower mixer taps" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
C
chipsndips
Water is coming through cold on the shower, and hot through bath tap. have taken off shower head as recommended by phil in an earlier post by berni967, and water is warm. What should I do/look for now?
HEllo, you have an imbalance of pressure it sounds like shower valves don't like that. You need to fit a prv and keep the cold. To the same pressure as the hot.
Tamz I don't ever post stuff on here or use this site as a rule because it's just full of DIY nut jobs that don't have a clue what they are on about. But last night while looking at some solar discussions I came across this post by chips and thought ok I'll point him in the right direction as sometimes you have to pass on done knowledge.
And then you post the above and it confirms all my thoughts, you clown. If you don't have anything constructive to say or don't understand what people want then don't say it. And if your qualified god help you.
Chips please message me, coz after this I'll be more than happy to help you.
With your attitude I'm sure I'm not alone in being delighted that you don't normally lower your self to use this site. I'd like to humbly suggest that you climb back onto your high horse and gallop off into the sunset.
Reply to the thread, titled "bath/shower mixer taps" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
