View the thread, titled "Bath Shower Mixer" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
A
Accord
Have an unusual problem,
Bath Shower Mixer , Thermostatic , Wall Mounted.
The overflow doubles as the Bath plug operator.
There is a constant dribble of clean water from the overflow/plug operator.
The Flat is a modular construction built in Germany and craned in pre finished the connected (about 8 years ago )
Has any one any experiance of this before? Cant think how a faulty Washer on the tap or thermostat could result in the dribble coming our of the overflow.
It could be a grohe i box fitted with an overflow and bath filler combined in which case a new seals kit would be required for the mixer ?
Yes that was my thought at first , have checked with other tenents and they fill the Bath from the single tap using cold side and the thermostat.
Have re visited the flat and turned off the water to the cistern, the dribble from the bath overflow stopped.
You were 100% correct adjusted the ball cock job done.
The cistern overflow is no more than 12 inches from the soil pipe, but they piped it over over 5 feet to the bath overflow ??
Anyway many thanks for your advice.
Reply to the thread, titled "Bath Shower Mixer" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
