View the thread, titled "Bathroom greywater waste to rainwater downpipes" which is posted in Bathroom Advice on UK Plumbers Forums.
L
logiccircuits
I've been asked to repair a waste water system in an attic-converted bathroom where a Saniflo was being used to remove WC, Basin, Shower and Bath water into the main soil stack. It couldn't deal with it and either requires 2 Saniflows or can I run the bath, shower and basin waste into the rainwater downpipe, which I'm pretty sure ( I will check!) goes into a combined rainwater/waste main drain. If I can are there any issues to be aware of re materials etc?
It is combined the RW. pipe will be into a trapped gully. (to stop sewer gases being emitted from pipe/gutter connection) Putting waste water into the RW. will promote odour and can not be vented at a higher level with success. It was the practice in years gone bye via a hopper head normally cut into the RW pipe at first floor level to receive bath/basin wastes.
if you dont get your facts right it could cost you big time if the water board find out,foul into RW=big fine,need to put a system in to suit your needs.
Reply to the thread, titled "Bathroom greywater waste to rainwater downpipes" which is posted in Bathroom Advice on Plumbers Forums.
