R
REDSAW
fault light for fan comes on and locks out!.
checked the ventury, took the flue apart, checked continuity of fan and aps wires, fan runs strong when running, changed the APS then nothing!. put the old aps back in and the fan ran at full speed but did not ignite boiler.
took the old aps out then put the new one back on and it ran fault less!!.
left the job yesterday and the tenant called to say it has locked out again!:/
the sequence goes to flicking the fan momentarily on and off for 1 second then eventually locks out?
i have done this twice now and left it running so the fault will be the same...fan fault indicator, please re read from the start................****!:sosp:
always happens to make you look an idiot in front of a new client with 200 properties😛rrr:
any one had this before as i am stumped?
i think mark is too?
ps. me thinking, could this be a relay on the board or a dry solder...broken harness?????
