View the thread, titled "Baxi 105e Combi Boiler - not hot water" which is posted in Boiler Advice Forum on UK Plumbers Forums.
W
w851ks4
Hello All,
I'm sure this issue has been 'done to death' so please forgive me if I'm asking the same question again........:winkiss:
I have a Baxi 105e. In the DHW mode there is no hot water (albeit there are NO warning/fault lights showing). However,there is no problem with hot water in the CH Mode.
I suspect it's a flow sensor problem or maybe a faulty diaphragm. Any ideas would be greatly appreciated before I call a plumber out.
I want to ensure that whoever is called out either has the parts required or I'll buy them for a plumber to fit.
Thanks.
could be a couple of things but if the no faults then sounds like either the diaphram or microswitch at fault, but could also be diverter valve enginneer will be able to tell you pritty quick which it is! were are you based im sure a gas safe guy in here would be happy to help
Reply to the thread, titled "Baxi 105e Combi Boiler - not hot water" which is posted in Boiler Advice Forum on Plumbers Forums.
