View the thread, titled "BAXI 105e Instant hot water getting colder as demand goes up" which is posted in Bathroom Advice on UK Plumbers Forums.
M
MCrant
HI
I have a baxi 105e instant, if i open the Hot water type slightly i can get continuous very hot water but if i demand more flow (ie open the hot water tap more) the temperature decreases.
I have checked and changed both the DHW and divertor valve diaphrams (both seemed ok)
Hi, and welcome to the forums.
Your combi is behaving perfectly normally. All combis will reduce in temperature as flow increases, and that is particularly noticeable in the winter when the incoming main is at a very low temp. The 105 instant boiler does have a small amount of internal storage (if enabled) which can fool you for a few moments into thinking that it is capable of higher flow rates than is the case on a sustained basis.
The very fact that you ask the question makes it clear that you don't have the expertise to be messing with your gas appliance, so can I politely suggest that you leave it alone?
And Ray doesn't even have a gas ticket to his name 🙂 But he looks after out interests, do you sell to ticketed folk only Ray, if so you get my vote for PM
Not quite lame. We don't sell retail, but thats not quite the same thing. Maybe a subject for the arms, rather than open forum?
There is a common fault on these boilers that will cause the water not to get very hot, but I cant tell you because we are not allowed to give advice to non gas safe people, so you will need to get a gs eng in.
Reply to the thread, titled "BAXI 105e Instant hot water getting colder as demand goes up" which is posted in Bathroom Advice on Plumbers Forums.
