Guest viewing is limited
baxi 80 eco combi. loss of pressure. need help please!
View the thread, titled "baxi 80 eco combi. loss of pressure. need help please!" which is posted in UK Plumbers Forums on UK Plumbers Forums.
studley
Have recently bought property, have never had more than 1bar of pressure with either taps on. Pressure has now fallen to zero and am unsure ho
w to repressurise properly. The water has always been hot on demand in kitchen but luke warm at best in bathroom. Compounding the problem now is that the 3 inlet/outlet valves are starting to drip and pump is overheating due to loss of pressure i presume? Boiler will not ignite at all. Any help would be fantastic, thankyou.
u need to find your filling loop to repressurise the heating system and the boiler will then work. pressurise to 1 bar on gauge
from what I can gather the filling loop is not performing properly for a start, that may need replacing. As for pressure drop it could be a leak; pressure relief valve passing (check the pipe outside); expansion vessel needs repriming or even damaged.
Reply to the thread, titled "baxi 80 eco combi. loss of pressure. need help please!" which is posted in UK Plumbers Forums on Plumbers Forums.
studley,
RoryD,
