hi there, have a bit of a problem with a baxi 80 eco combi,
i replaced the PCB as this is what i believed to be the initial problem, fired the boiler it ran for half a minute before popping both the 3a fuse in the spur then the 2a quick blow. so i called baxi tech (heat team) and they inform the only things that could pop the fuse are the pump, fan and gas valve. so I check the resistance over the gas valve which is fine then the fan which i s low and they recommend i change so i change the fan only find its doing the same thing! im not ruling out that the pumps jammed but if anyone could highlight anything else i should check or any advice at all id be incredibly grateful.
