View the thread, titled "baxi back boiler fire" which is posted in Boiler Advice Forum on UK Plumbers Forums.
buckley plumb
serviced a back boiler and the fire got me puzzled for ages thought i had a gas leak - it must have been an old fire it had a permenant weep pilot once lit it stayed on no safety device to cut it out any one seen these before - for the moment i have isolated the fire untill i get intouch with baxi
there quite common seen loads relight it and back to normal i assume its a massive wood effect g plan fire?
are these the ones with lights under the shelves, commonly known as a piece of furniture
yes,quite big you turn a brass screw on the RH side of the fire to knock off the pilot light
yeah i have serviced these before test it with pilot isolated then check for leaks on pilot assembly and tubes for leaks after
There are still a few permanent pilot fires (and cookers) around so learn how to test them.
i think weve all done that at least once so rare now it comes as a suprise the one i used to hate was gas fridges that were lit by putting the plate with a hole over the flue then waiting for enough gas to rise up the tube to ignight it
Reply to the thread, titled "baxi back boiler fire" which is posted in Boiler Advice Forum on Plumbers Forums.
