PeteW
Hi. I have an elderly Baxi Bermuda backboiler, not sure of the exact model, but it is 30+ years old. The system has gravity fed hot water, vented system & pumped radiators with one 2 port valve & a thermostat in the hall. It is working ok with several issues.
Firstly our gas bills are enormous! Almost double the average for our type of property, although our usage is not excessive.
Secondly when the pump cuts in there is a banging from the upstairs radiator piping, loud & for several seconds, also adjustment of thermostatic valves on upstairs rads causes banging. Looking at the thermostatic valves they are the old unidirectional type, & the flow is in the wrong direction which would explain the banging. The only exception to this is the bathroom rad thermostatic valve where the flow direction is correct, but this seems to be plumbed to the gravity feed, which I understand is quite normal.
The pump was replaced about 4 years ago. Having trawed around as many references as I can from google (including this excellent forum) I wonder if the pump was replaced pumping in the wrong direction. Currently it pumps away from the boiler which is situated almost directly below. I have seen in one post that often with these older installations pumps often should pump on the return toward the boiler & installers can get this wrong.
My query is...If the pump is installed incorrectly, would the system continue to work ok as it has been for quite a while, with the exception of incorrect flow through the thermostatic valves & the high gas bills. If I reinstalled the pump so it pumped towards the boiler to test it, do I run the risk of any damage in this pretty basic system.
Just to say I'm not a plumber or heating engineer, but pretty handy DIYer!!
Thanks in anticipation.
