proelitegas
Hi...was called out to fix a leaking radiator valve and add sludge remover to the system..no drain off valve anywhere in the system and could not find a f&e tank in the roof space...found cwsc that supplies the direct copper cylinder which works with electric immersion heater to provide hot water...i am a little baffled as i was thinking the boiler will have a f&e cistern which i could add sludge remover to when i drain down can not find it any where also no drain valve found i can drop into the void under the house and cut into one of the central heating pipes and let the water drain into the void and fix the leaking valve and install a drain off point but cant find any f&e tank..any 1 out there that can advise would appreciate it..Thanx
