View the thread, titled "Baxi combi 80e dhw issue" which is posted in Gas Engineers Forum on UK Plumbers Forums.
Hobo128
Called out to this boiler last night....
No hot water... Heating fine...
Run the hot tap, boiler does not fire.... Pin on diverter does not operate.... if I manually press micro switch boiler fires.... I am going to replace the diaphragm in the diverter valve tomorrow... However! I have tried this before and still no joy.... In fact I have done this twice and it's not worked... what am I missing if it decides to not work
There’s a pin in the back of the front diverter housing normally requires a rebuilding you can get a rebuild kit online
Reply to the thread, titled "Baxi combi 80e dhw issue" which is posted in Gas Engineers Forum on Electricians Forums.
