M
maggsy
Hi Guys,
My first post so please go easy on me, I have a gas Baxi Combi Eco80 boiler, it has a strange problem, hoping one of you guys may be able to shed some knowledge on what could be causing the problem, I'll give an overview of a typical day in the boiler, here goes:
Boiler turned on as normal, I go to wash up, hot water comes on fine no problems at all, again go sit down watch TV, go upstairs to toilet, wash hands, hot water works fine. Its feeling a little bit cold in the living room so I turn on the central heating, I set the thermostat to say 25 degrees, the boiler and central heating work fine. HOWEVER -- When the heating gets to temperature it will just cut off and will not allow you to turn it up higher and the hot water will not work and the boiler just stays idle, it will not spark up it seems. If I then leave the boiler to rest for say 2-3 hours it all starts to work fine again. The process will then all happen again - Hot water fine - turn heating on fine -- gets to temp (or just under) boiler cuts out -- hot water will not work -- leave to rest for a few hours then boiler will start to work. I also must add that yesterday I did not use the central heating all day and the water heated up with no problems all day.
Hope someone can shed some light on this problem -- I would say that the way the boiler operates until cutting off is normal, no strange noises etc
Hope you can help,
Hope you can help,
