View the thread, titled "Baxi duo tec 28he" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Boiler1978
Hello all,
Before we start. .... hope you all have a happy crimbo and all that.
Anyway,
I have a Baxi duo tec 28 he and the return isolation valve on CH is leaking at the union between the filling loop which is integral not a hose type affair. It is leaking at the nut which secures the copper bend to the actual valve.
Are washer/seals availible to replace or do you need to replace the whole valve.
I cant find just seals so bought a replacement valve with a plan to replace just the seals, but this is a different valve as it is much thicker bodied if you know what I mean. The original is thin by comparison but it looks like it will fit.
My question is.... If you cant buy just a sral/washer, how do you remove the nut which is at the top which is impossible to get at to turn because of all the other pipes.
A seal/washer would remove my need to replace this valve so any help or advice on how to change would be a great help.
Thanks guys and girls....
Sometimes the magic isn't knowing what to do but how to do it.
A lot of the time it looks impossible but you struggle on.
It will ve awkward, and whatever you do don't impact the gas side.
Reply to the thread, titled "Baxi duo tec 28he" which is posted in UK Plumbers Forums on Plumbers Forums.
