View the thread, titled "Baxi duotec 40 flow restrictor on mains in" which is posted in UK Plumbers Forums on UK Plumbers Forums.
A
Abersoch
Hi - just installing my own Baxi duo tec 40 as have had new water mains supply and water pressure is very powerful. On installing I noticed in the manual it says there is a flow restrictor built into the cold water inlet tail nut which connects onto the jig - my question is why would they restrict the flow only on the 40kw model, as I only bought this model to achieve as best hot water flow rate as possible.
it can be removed it's only a small piece of plastic loosely inside the nut, any ideas ?
thanks
I'd be amazed. Op pm me your gas safe details. Amaze me.
No DIY boiler advice offered here.
thanks
Could you give me the serial number as different flow switches are used
Reply to the thread, titled "Baxi duotec 40 flow restrictor on mains in" which is posted in UK Plumbers Forums on Plumbers Forums.
