View the thread, titled "baxi eco 80 - pressure dropping (prv passing by)" which is posted in UK Plumbers Forums on UK Plumbers Forums.
M
moony
prv faulty so going to replace that, pressure low, but when i run the hot tap, the pressure goes up slightly? turn it off drops again.
any ideas. dhw heat exchanger passing?
its my mum and dads boiler and i will be replacing in the summer or autumn but could do with it lasting a bit longer
yeah could be that puddle pal, the prv is defo passing so will change that and go from there
cheers
the prv needs a reason to fail,filling loop faulty,expansion vessel faulty,doubt its the dhw heat exchanger but could be and why replace it? its a excellent boiler and parts are cheap for it😎
Reply to the thread, titled "baxi eco 80 - pressure dropping (prv passing by)" which is posted in UK Plumbers Forums on Plumbers Forums.
