Baxi fire front compatability
View the thread, titled "Baxi fire front compatability" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I have a Baxi 552 back boiler,don't laugh but because it's been so good I want to keep as long as poss. My gas guy has told me i now need a replacement fire front so I am looking out for one.As I understand there are two fronts for this boiler one with ceramic radiants which is mine and one with coals and a glass front.Will the latter one fit mine without any modification.Thank you
Yeh, one’s the SP and ones the VP. Both fit the 552 or 401.
Are you Gas Safe Registered Mate? If not please do not tell people what will and will not fit their BBU. If you are then send your details to me and we will sort you out the correct badge.
So I guess I can't get an answer on here,just wanted to do a bit of groundwork, didn't really want to phone Baxi myself as I can imagine they would be a bit stand offish re the fittment of pre owned parts.
So are we .
We can’t recommend buying a second hand fire front, to an already very old boiler.
So are we .
OP: Be careful, as fires that fit the 401, the 551 and the 552 will look similar - but are not compatible. Only use a fire that has come off the same model. You are likely to need a new connector as well, but the RGI should be able to sort that out.
As I have been (IMO, extroadinarilty) edited, I will rephrase it:
OP: provided all is done safely, there is nothing wrong with using an old fire or boiler. Whwn Chalked says "We" it should not be taken, categorically, as referring to a greater number of professionals than himself
And neither should the above be.
I suppose in a ideal world I should just replace the the whole system but am a pensioner who just hasn't that sort of cash.There seems to be a bit of can, can't, shouldn't really opinions, which is a bit confusing but if I am understanding correctly, i can replace the fire with a like for like and would also be able to use the other type of fire as long as it came off a 552 (which it has).If this is not the case I will just look for an excact replacement.Thank you for taking the time to advise me, my GS fitter is on holiday so can't ask him directly at present.
If I had the correct fire in front of me . I would fit it. But “we” means the general forum advice ,given to a poster, who we have no idea if he has the correct fire or not.
TBF, this is the problem to which Chalky eludes. I gave, IMO, safe advice. You have slightly ignored it. Your "exact replacemet" may not be an "exact replacement", hence my caution that you only go for a fire (irrespective of the model) that originated from a 552.
Here you go.
Reply to the thread, titled "Baxi fire front compatability" which is posted in UK Plumbers Forums on Plumbers Forums.
Bikerblue,
Bikerblue,
