View the thread, titled "Baxi Megaflo System 24 H A pipework ?" which is posted in Gaining Plumbing Experience on UK Plumbers Forums.
F
fred10x
hello
which size and appropriate heating pipework for Baxi Megaflo system 24 H A Baxi Megaflo System HE A
along with any associated heating plant and equipment ?
this is for a 3 bedroom house
any input in this is very appreciated
thank you
It may not involve the unvented cylinder as Baxi call their System boiler Megaflow as well ! However it is still not a DIY job as it is a gas boiler. Give us a bit more info fred , what exactly are you doing ?
sorry for the confusion! of course there's no DIY job! this is just a little exercise i am doing trying to see if i can go fo HVAC courses ... so far i have done most of the work by calculating heat load and picking up a heating system from a manufacturer ( it is all about heating ) but the last part i am stuck from yesterday spend hours on Google and i got where i am not sure i understood what i have to do
for HS i picked up this baxi megaflo system 24 H A ( 24kW model after calculated heat loss) which can deliver heat and hot water easily for a 3 bedroom house mid terraced
i also picked up Single panel double convector ( 8 of them )2x 1400mm 3x 1200mm 2 x 700mm Single Panel Single Convector 600mm Radiator 600mm Height x 1400mm Width - Ceramicas available at Plumbworld
this is where i am a bit not sure how i can determine pipework for this system
my understanding so far is... to determine the size of pipe, i have to calculate the Flow rate for each Radiator with this formula
flow rate = radiator power input / 46000
and then the resistance flow
finally i can determine the size of pipe from this table
Central heating pipe sizing
am i doing this correct? also the manufactures doesn't display the radiator power output for all Radiators, some of them displays 2 outputs
for example for the 600mm x 1400mm you have 4537btu at 50c and 5812btu at 60c
which one i have to use for my calculations?
i would appreciate your help in this matter...
thank you
Reply to the thread, titled "Baxi Megaflo System 24 H A pipework ?" which is posted in Gaining Plumbing Experience on Plumbers Forums.
