Guest viewing is limited
Baxi Solo 2 40 RS Replace thermocouple - GSR job?
View the thread, titled "Baxi Solo 2 40 RS Replace thermocouple - GSR job?" which is posted in General Plumbing Jobs Discussion on UK Plumbers Forums.
V
vido.ardes
I just wanted some advice on whether the job I need to do has to be done by someone who is GSR. I have a Baxi Solo 2 40 RS and the pilot won't stay lit, 99% sure it is the thermocouple, I have bought a new one and it seems extremely simple to replace. Is it a job that I need paperwork to prove someone GSR did it? Am I gonna have trouble next time I want a service and I can't prove it was done by a GSR? It seems like such a simple job I am reluctant to pay someone £50 to do it, but if thems the rules then that's what I'll have to do.
Welcome to the forum vido.ardes 🙂
Is this your own home?
Legally only competent people are allowed to work on gas appliances. The way someone is recognised as 'competent' is that they have been trained and are registered with gas safe. What you do in your own home is entirely up to you. However should something go wrong then would you be able to live with yourself? Why not have your appliance serviced by someone GSR. I'm sure they'd replace the t/c as part of the service and charge you additional for the part only, should that be at fault. The T/C is a safety device, if it's tripping out there may well be a reason other than it failing IMHO 🙂
Thanks, I was assuming that would be the case. It is my own home, we have only recently moved in, but I want to spend as little as possible on it because I am currently fielding quotes to have it replaced as it looks about 20 years old! Trouble is I haven't got £2k spare so replacing it right this second isn't really an option. I will get it serviced and see if they will do it during the service, like I say I have already got hold of a replacement t/c from plumbase.
Thanks for your advice, will probably be coming back to get advice on what to replace it with! 😉
Reply to the thread, titled "Baxi Solo 2 40 RS Replace thermocouple - GSR job?" which is posted in General Plumbing Jobs Discussion on Plumbers Forums.
vido.ardes,
diamondgas,
