View the thread, titled "Baxi solo explosive ignition" which is posted in Central Heating Forum on UK Plumbers Forums.
Steve weightman
Visited a baxi solo 24he with explosive ignition so looking for spark electrode issue or gas valve issue or even inlet pressure but all looking ok. One thing I noticed was the programmer is faulty flicking on and off . Just a thought but would you think this could be the issue partially ingniting then not then igniting again with a build up of gas.
Cheers
I'm not that experienced with fault finding etc but if there was a build up of gas wouldn't the fan pull the excess gas out before ignition? In which case could it be a wearing fan lacking the power to clear the excess gas or not pulling in enough air before ignition?
If I'm taking complete nonsense please feel free to tell me 😉
So is the thinking that with dirty, slightly bent out of shape electrodes, the spark will be weak, causing a delay in Ignition which is resulting in a gas build up? Sorry, I know I'm not helping just trying to build up my understanding.
If I’ve think correctly the Baxi solo same thing as the potterton promax 15/2 he.
If so the Id change the electordes also make sure it not sparking on the front of the combustion case. The silicon tubes give it over time.
Make sure the condensate trap and sump is clean.
Check that type of burner you have the earlier versions had a fibre burner (it caused many issues). Id replace it for a new ceramic burner.
Reply to the thread, titled "Baxi solo explosive ignition" which is posted in Central Heating Forum on Electricians Forums.
