W
waynedance
Building a well insulated conservatory (4x2.8m) will a 1 x wall made from 4x4" with insulation.
House has a combo boiler in the bedroom cupboard will 3 rads upstairs and 2 down. All have thermostats except the double rad in living room. Could I run a pipe from kitchen rad to Conservatory? Would this work if it had a thermostat on it to keep it above freezing?
Ok thanks, what does that mean? What would I need to fit then to keep it above 5 degrees ish? A separate electric heater?
It means it must be on a seperate thermostatically controlled zone to the rest of the property.
Some fit sleek electric wall mounted heaters instead of a zoned radiator circuit
But also check the definition of a conservatory as opposed to an extension built for lounging about. The devils in the detail.
If its by enlarge a brick built structure with conventional type windows, roof a patio door that would not make it a conservatory.
Just saying as some refer to theirs as a conservatory when clearly is isnt and the rules may not apply
Is a conservatory, 4x4" wood dwarf walls cladded, double glazed with 35mm polycarbonate roof.
Got to do something, will go with a rad with thermostat from main heating… yeah I know regs this and regs that.
Got to stop it from freezing… going to have a fridge and freezer in there along with some furniture.
nothing like a frozen rad in the winter leaking everywhere, yeah I know regs this n that, normally there for a reason though
Reactions: 3 people
What about a separate gas supply installed with a gas heater?
All I want is to frost protect.
Stop being a cantankerous old sausage
SO sorry, but it makes me see red to try and heat the world, we are to hot already, conservatories are for flowers over winter and arent living accommodation, the sooner the world understands this the better for the world
We're already paying 5p for carrier bags it's time to make a stand!
If your putting a freezer in there you will need it a lot warmer than a few degrees unless you use a cold weather freezer most manufactures recommend 14c upwards iirc my old one in the garage started to self defrost so had to move it into the house to make it freeze again the refrigerant needs to flow and can't if the outside of the freezer is too cold
Most efficient an cost effective way with the fastest warm up times is a good quality turbo electric convector such as a wall mounted dimplex.
A good quality one has a good thermostatic control and also variable power settings along with a programmer.
And make sure you have well insulated doors seperating the structure off from the rest of the house.
Each to thier own but imho a radiator is not the best option alot of the time in these
Air conditioning is the only way keep a conservatory comfortable as without it they are to hot in the summer and to cold in the winter. I have fitted hundred of heat pumps (as there called by some) with very satisfactory results. But ultimately you are trying to keep a glorified greenhouse heated or cooled which will obviously use energy
Will look into the electric convector, main goal as said is to frost protect and be able to warm up when want to use.
Is advise a turbo (fan assisted) type. Makes a world of difference over convector only
those heaters are rated at 2.5Kw & 3.0Kw an air conditioner would give you 3.0 Kw of heat with just 800w input
that dimplex one works very well, i put one of those on my mums con-wall.
it heats the lot in 10 mins.
How does that work then. Have they rewritten the laws of physics.
800w in = 800w out.
1st law of energy. It can neither be created or destroyed - just transferred.
I take it under floor heating is a no no… does that work on a thermostat is that expensive to run keeping above 5 degrees.
I am looking at the turbo Dimplex rad but misses asking about under floor heating.
Id forget about underfloor. Easily the most expensive option but I suppose its horses for courses and what you desire.
Any electric heater will work and will be cheap to buy. Underfloor heating works well but not for short periods i.e. on or off . don't forget about the summer which is when most people use their conservatory that it will be unbearable without air conditioning. don't spend (waste) money having a radiator fitted as it will take far to long to heat unless it is big enough and the heating is on long enough. I am not trying to sell my advice is from my own experience. ps I do not install air conditioning
Any electric heater will work but some will work very well compared to others.
For example look at the heat curve of an oil bath heater compared to a fanned convector.
Both could be 3kw. But the oil one wont feel like it.
800w in = 800w out.
Typical heat pump, 800W in, 3200W out, COP of 4. Actual performance will depend on temperature differences etc.
My conservatory/sun room/whatever you want to call it at home is an infill between solid brick external wall and kitchen extension with triple skin plastic roof. I've recently put in new tiles to both it and the kitchen with electric heating mat underneath. Works a treat and most times I only need the floor slightly warm to keep me tootsies warm when I'm walking around barefoot!
If your still building your conservatory, personally I would think about using electric ufh, and fit with a vinyl floor karndean, Amtico etc. cheap to run and the vinyl floor isn't as cold as tiles when the heating is switched off.
Under floor heating is quite cheap as far as I can see… was just thinking thats a bit late for a reply. But hey I'm still up ha
Best way to heat a conservatory is run an extenion lead into next doors and run a heater even with pollycarbonate roof it will cost a fortune to heat
A heat pump is another good move, with a 3/1 conversion it makes sense, you get a 3kw heat pump its only going to use 1kw, more expensive to fit, but someone says if you fit a radiator off the house it may well freeze up and you will never be warm in there.
The best way to heat a conservatory is, of course, the sun.
Some ancillary back up may be required if you are proposing to cultivate frost sensitive plants.
A paraffin heater on cold nights is not a bad idea, it increases CO2 and humidity.
Unless of course you are proposing to use the "conservatory" as a kind of living area?
H
3K
UK Plumbers Forums
Deleted member 120897
