View the thread, titled "best way to repair?" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
T
Tim1984
hi. i have a chip in my basin pedestal. whats the best method of repairing it so that it doesnt stand out as much... without replacing it
Little chip/ scratch = repair kits, widely available - doesn't even have to be white but the colour matching ones won't produce such invisible results
Big chip/crack = worth replacing for safety reasons. if it falls apart when somone leans on it it'll slice them in twain
I use car repair products for this kind of thing. You get whit wax sticks that work well even fillers and white paint not srays but the stick with the brush. T Cut white works well on the odd scratch on a bath or a tray. I mamaged to take a fairly deep chip out an idealcast bath after my level fell into the bath.
We used to have a company come in to repair things like your problem, the company was called the plastic surgeons, they would do work tops and all sorts, they did a really good job
i use a little kit i got from toolstation its a tub of filler which you rub down with some very fine sand paper which is provided then mask the area and spray white stuff over it.
i used it a couple of times and its pretty good. after paint is dry you need to t-cut over the patch to fade in the raised lip from when you masked up.
works well on plastic baths as well as pot stuff
KJ
Reply to the thread, titled "best way to repair?" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
