5thblyscouts
I stupidly decided to balance my radiators this morning as the ones furthest away from the boiler were cool. I followed the instructions found on the internet and everything seemed to be going well until I bled the bathroom radiator, topped up the filler loop a little and then turned down the CH knob on the boiler. It turned off and after a few seconds the normal operation light started flashing quickly (usully it is 1x green flash per second) at the rate of 4x flases per second.
The temp. guage looked a bit higher than usual so I turned the boiler off at the switched spur and let it cool down. I opened all the valves on each of the first floor rads (in case I had caused the boiler to overheat through restricting flow arounf the circuit) and after 20 minutes turned the power back onto the boiler. The normal operation light flashed as usual at one flash per second as I called for heat with the switch. It made various clicking and gurgling noises before it turned off and the green light started flasing at the faster rate again. I repeated this operation a few times but to no avail. It is freezing outside and now inside !.
I opened the PCB panel and checked the fuse to the fan/pump and it looked ok so popped it back and tried to restart the boiler. The same thing again but I noticed this time that when there was a click and change to the flashing light sequence a green led in one of three small plastic housings on the PCB flashed as well.
The service lights are not flashing other than the normal operation light.
Can anyone offer any advice. I have taken a phot of the circuit board and can post if required.
Thanks in advance.
Thanks in advance.
