Guest viewing is limited
Biasi Riva 24 no attempt to fire up
View the thread, titled "Biasi Riva 24 no attempt to fire up" which is posted in UK Plumbers Forums on UK Plumbers Forums.
dazwalsh
I have a Biasi Riva 24 combi that appears to be functioning correctly, that is no lights to indicate fault. The problem is the boiler makes no attempt to fire up when turning on CH or when asked for DHW.
when i turn on the hot tap i hear a click but nothing else, the lights to indicate DHW operation come on but there is no pump, fan etc to accompany it.
Same with CH, it just sits there with its lights flashing as normal.
i first assumed a problem with the PCB but that itself seems to operate completely normal, so whats next in the sequence of start up? Pump? Fan?
its a rental so I'm going to take a look at it tomorrow morning again but would like to know what happens in what order when the boiler is called for. That way by order of elimination i can get it fixed.
Any help would be appreciated.
Many thanks in advance
Darren
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to the thread, titled "Biasi Riva 24 no attempt to fire up" which is posted in UK Plumbers Forums on Plumbers Forums.
dazwalsh,
Dotty,
