Guest viewing is limited
biasi riva
View the thread, titled "biasi riva" which is posted in UK Plumbers Forums on UK Plumbers Forums.
billybob150811
serviced above boiler flue terminal disintegrated ,poss because of uv or condensate has anyone had this and should/will biasi provide a new one or do I just buy one if their available
to answer my own post phoned biasi I said the white flue terminal is as brittle as 1000 year old parchment and he said oh the flue terminal is black I will give you the correct part no, looked it up and its white so the answer is its a piece of tat which falls apart if you touch it
Reply to the thread, titled "biasi riva" which is posted in UK Plumbers Forums on Plumbers Forums.
billybob150811,
billybob150811,
