View the thread, titled "Biasi Rival compact combined boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
U
Unregistered
I have a Biasi Riva compact combi boiler. At the moment it is on summer settings with the DHW set to its minimum. When I run a hot tap the water gets extremely hot and is unbearable to hold your hand under the tap. The thermometer on the boiler displays 60 degrees after 20 seconds of the tap running. Is there an internal thermostat that should control the dhw?
if the consumer controls are set right, please call a gas safe engineer out
Reply to the thread, titled "Biasi Rival compact combined boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
