M
mkohman
Hey All,
I am having an issue which I am scared to turn the central heating on now at night.. Basically I have a Biassi RIVA COMPACT HE M96.24SM/C Boiler and for the past few days it has started to make a kettling noise "also sounds like an aircraft taking off" then the boiler cuts out.. What I mean is the flames turn out and the boiler stops.. After a minute of so it fires back up for 20-30 secs and then the kettling noise again and cuts out again.. this goes on and on.. and just recently there becomes a rumbling noise like something is tuck in the boiler and the flames seem to rise higher than usual and then it cuts out..
Does any of this makes sense to any of you guys? Please can you assist me or advise what may be the problem..
PS: I just recently took out the heat exchanger and cleaned it with citric acid.. It is clean .. I have suspicons it may be the pump but I am not sure??? when I do unscrew the little screw on the pump it is turning and water comes out of it.. Please help !!!
