View the thread, titled "Bit of a strange visit from Gas safe...." which is posted in Gas Engineers Forum on UK Plumbers Forums.
R
Ryster
Hi chaps.
Not posted for a while but I'd thought I'd ask the advice of some I dependant knowledgable guys so came on here :tounge_smile:
A guy that works at the company I work for had his first visit from Gas safe today. Everything was going really well until the end, when the guy, without mentioning any of this during the assessment pulled out two points which he said "could potentially cost him his certification".
Now the first one was continuity bonding whilst taking a meter off, he placed the bonding on the inlet ecv and then on the outlet pipework. Then after he had replaced the meter he removed the bonding from the outlet pipework then the ecv.
The second issue was on his initial drop test, he connected his manometer tubing to the test nipple, and let the pipework pressure down to 9mb, releasing the gas through the tubing.
Now, rather than say anything whilst this was happening he's pulled him at the end and said those two things were done wrong and a report would be submitted.
Personally, I've never had an issue with assessments, however I'm curious to know what will happen to the guy because of this. He's geuinely bricking it now but I'm really confused as to what's going to happen and why he's even really pulled these rather than mentioning it there and then?
did he tell you why he thought they/he did them wrong?
as tbh i dont see nothing that bad (wanting reporting et)
He gave those two reasons I mentioned as the reason he was going to report him.
He said the continuity bonding was put on incorrectly and he shouldn't have been releasing gas through the tube to take the pressure down for a drop test.
The second one really has me confused though, as I've been Qualified for near on 10 years now and in the training center and on site, National Grid, anyone I've seen doing a drop test drops the pressure through the tube to take it down to 10mb.
I'm really confused for the lad to be honest, and nobody I know can really understand what the issue is.
regarding the drop test thats bs, anton even make a thumb screw thingy to save you pulling the tube off google PRV Anton pressure relief valve
wtf is that guy on?
how else would the pressure be dropped it looses more when you take the tube off to replace the nipple!
i would of pulled the gs guy there and then and asked him to justify his findings and attitude.
wtf is that guy on?
Unfortunately it was the lads first assessment so he was probably unsure in his own work with the supposed main man telling him he's wrong.
Our gaffer has caught wind of it and is fuming, he's ringing them tomorrow to find out what the problem is.
I just hope he hasn't got the continuity the wrong way round, he said that he told the guy "inlet first" and then clamped onto the outlet, and he's taken the outlet off first and finally the inlet, he says he went on the "last on first off" way.
Hope he's not got that wrong, but even so is that worthy of a report?
tbh it doesnt really matter as its earthed before hand (via bonding ) once meter is off its earth via fly lead, then meters back on and being earthed (via bonding)
but dont forget the meter bracket is metal so unless your changing the anaconda or meter union its earthed anyway
GS guy sounds a proper muppet, i would have to dust off my tcbs before an inspection, what does it matter how you drop the gas pressure? the gas has gotta come out some way. Thats a controlled escape of gas through the tube
Well its this that Ive quizzed him on. He had to remove the meter to replace some pipework, so hes put on his temp bonding in the order ive said and placed the meter outside.
The guy even had the cheek to compliment him on purging through a cooker :59:
Hopefully we can find out more tomorrow, I jusg think its terrible that some guy has someone worried for nothing really. I thought the days of the assesors being tools had gone....
tell the lad not to worrie if thats all hes been picked up on hes fine, and will get sorted
so the lad has passed his exams and the inspector says he doesnt know enough, they are supposed to be there to check your safe no more no less not make you do another set of exams, pratt
So an update.
Our boss spoke with the assessor this morning, the assessor ISNT reporting the lad for anything. It would appear that he almost nearly forgot to LDF the test nipple, but before being prompted he checked it.
With regards the temporary bonding the lad has clipped his temp cable onto the actual ecv. The assessor said that if he had been removing the ECV this WOULD have been an issue but as he wasn't there wasn't a problem.
Can someone just confirm that placing the temp
bond clip onto the ECV isn't an issue when working on pipework? As stated yesterday it's in between the ECV entry and the outlet, so there shouldn't be any issue there should there?
Anyway, apart from that the assessor said he was more than happy with what the lad done, and was a little bemused as to why the lad thought he was being reported when the assessor was only giving examples of issues that could arise.
To me it seems like maybe the asessor has said something and the lad has either misinterpreted it? Either way he's a happy bunny this morning.
I'm guessing he got a bit stressed yesterday. I still suspect the guy assessing him was maybe a bit more arsey than he was on the phone this morning to our boss, but either way it would appear it's all ok.
All's well that ends well, put it behind him now
Saw the lad today and he was quite downbeat about it, might have hit his confidence a bit but our boss said the same thing. It's all done, nothing happened and he wasn't doing anything incorrect.
Cheers for the replies chaps, appreciated.
Reply to the thread, titled "Bit of a strange visit from Gas safe...." which is posted in Gas Engineers Forum on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
Gas Engineers Forum
Start date
Last reply date
Ryster,
SmokeyJ,
