defender1007
Hi all. First time using this forum. Here Goes: Noticed overflow pipe running from header tank in loft at my sons property. On checking part 1 ball valve slight leak from washer. Bent valve arm and stopped leak but I will be upgrading to new part 2 ballvalve in near future. Decided to check mains stopcock working but seized solid so will attempt to free or replace asap. Noticed rising main is a black poly pipe into stopcock. I was expecting to see MDPE. Is this an imperial pipe? and can i fit 15mm stopcock to this. When doing some plumbing way back in the property I remember some copper pipes were imperial and I had to use adaptor olives.
