View the thread, titled "Bleeding rads" which is posted in UK Plumbers Forums on UK Plumbers Forums.
K
kev42204220
hi, one of my radiaters is geting air in it quite a lot. it often has a cold patch at the top and i have to bleed it. it is just that one, upstairs radiater. any cures very welcome.
kev
leaks in system, what kind of system are you on vented or unvented, combi etc
I have a old back boiler with a vented hot water cylinder. think its quite old. not aware of any leaks or drips thow.
like redsaw has said it could be due to pump location, system pumping negative rather than postive thus sucking air into system.
the pump is downstairs, rads are fine there. rad in bathroom next to the cylinder is fine too. i was going to bleed the pump but it has been placed in a way to make that imposible with out removing it!! .😕
Reply to the thread, titled "Bleeding rads" which is posted in UK Plumbers Forums on Plumbers Forums.
