View the thread, titled "Blocked Hotwater tap." which is posted in Plumbing Advice for Any Other Country on UK Plumbers Forums.
J
jc1
My hot tap over my bath is blocked but all other hotwater taps work fine, i believe i need to flush the air blockage out can anybody tell me how to do this please??
if the cold is mains fed use that to push the hot water backwards pushing airlock out.
have you a mixer tap on the bath ?
Upvote 0
Yes i do have a mixer tap can you tell me what to do so i can stop my missis moaning
its happened about 5 times before and it needs to be flushed but i cannot afford to get a plumber out again.
Upvote 0
are you sure its airlocked ?
how did it cure before ?
if your sure its airlocked you can block the spout open the hotside and then open the cold side that will push the top backwards to clear air.
try that for a min or two it should clear.
must be cold mains to work not gravity.
Upvote 0
am wi you sonray not sure about air lock how did they connect a mixer tap didnt know you could?
sorry slow typer your to fast sonray buti didnt know you could do that learn somthing new every day
Upvote 0
what do you mean how do you connect a mixer tap ?
a mixer tap in a bathroom mixes in the tap or spout.
a kitchen mixer doesn't mixer to water leaves the spout. they have a tube inside a kitchen mixer that seperates the water.
Upvote 0
get the wifes dish cloth and block the spout, don't need to be 100%.
hold the cloth from blowing out.
turn on hot tap.
then turn on the cold.
cause the water won't come out the spout it will go up the hot feed pipe because the cold mains is stronger pressure than hot gravity.
after about a min turn off the cold and pull the cloth out the hot should be running fast.
Upvote 0
now you are getting me confused whats going on.
bad plumbing.
is it only on that tap ?
Upvote 0
not knowing the system layout etc
its getting air from somewhere that really should be going out the vent pipe and not the tap.
Upvote 0
Reply to the thread, titled "Blocked Hotwater tap." which is posted in Plumbing Advice for Any Other Country on Electricians Forums.
