hi, when doing a boiler and cylinder to combi conversion, do you have to re-pipe all hot water outlets from the boiler or just remove some of the 22mm as much as is reasonably practicable?
Also, if the customer has a thermostatic mixer shower fed off tank and cylinder, if you put mains pressure hot water off a combi to this, surely it will be higher than the tank cold pressure on the cold side of the mixer, override it and not mix properly?
Would you also have to re-pipe the cold to the shower? Or even rip the cold water storage tank out and convert all the cold to mains? Theres probably a number of ways but I just wanted to know the general consensus.
