View the thread, titled "Boiler bang noise after system drain and refil" which is posted in Boiler Advice Forum on UK Plumbers Forums.
A
Anthonyb6000
Evening all,
I drained my vented system today, added some cleaner into header tank (with a view to repeating process in near future with inhibitor) and refilled. I blead air from downstairs rads and then upstairs after re filling.
Turned on boiler tonight and listened, pump in airing cupboard seemed to be working ok, slightly different noise, which I expected for a short while anyway...then after maybe 5 minutes the boiler downstairs started banging (pretty loudly) maybe every 5-10 seconds. I switched it off after about 4-5 bangs not wanting to do any damage. Boiler had been working fine.
Question-is this normal to experience after a refil? Should I man up and let it do it's thing for a while in the hope this will stop after a while?
any help appreciated!
sonds like you mis-diagnosed a heating system that wasnt running 100%?
or what he said if it was!lol
Thanks guys, I thought as much - best remedy? I've re-checked the rads and the pump, all blead. Can the air escape over time or do I need to get an engineer in?
Do you have any air vents at the high points? Sometimes it takes a few attempts to bleed the air, try the pump a few times to see if its still letting air out.
Thanks guys, I went round and drained a little water from the downstairs rads and then attempted again (I searched unsuccessfully for blead valves on pipes) this time I moved the pump setting to 3 from 2 and back again after a few seconds then back to 3. Touch wood, rads are all on and no banging.
Question - when shall I move the pump setting back to 2 (or should I kepep it on max)
Many thanks
Many thanks
Leave on 2
Many thanks
pump clogged with krap/not working like i said. it could also be on way out. put new one in ready for winter in a couple of weeks!!!.
In future bleed the pump and before refill manually open and zone valves if u have them,
Reply to the thread, titled "Boiler bang noise after system drain and refil" which is posted in Boiler Advice Forum on Plumbers Forums.
