buckley plumb
been called to a boiler today as british gas did an ID on it as it was on a contract and been passed by them each year till now .It was an older boiler i have never heard of its about 6years old - its in a terrace between the kitchen and bathroom and has no external walls , the condense goes into a drain connector 40mm to 4" in the floor in 40mm pushfit pipe and due to the bathroom having a floor fitted 3" showertray they put the blow off into the 40mm pushfit pipe with the condense. it has been Id due to this - my question is that G3 allows for an unvented cylinder to be into a drain via push fit so why not a combi blow off ? also i have seen a condense pump that accepts a blow off as well so if a conense pump can why not a waste .
ant
ant
