View the thread, titled "Boiler change" which is posted in Boiler Advice Forum on UK Plumbers Forums.
MZR
Hi All
I have a customer who has a ideal mexico rs125 which is quite old hes asked me to replace it for a new energy efficient system boiler (recommendations welcome on this also) but the problem is he has a log burner which is connected to the flow and return and he uses this alot , hes rewired the pump from the ideal to circulate the CH flow and return when using the log burner to save gas. now all he has asked me to do is change the boiler if i change the boiler will the pump and log burner still work in the same way or will the pump/log burner cause a problem with the new boiler ?
hope this makes sense ? thanks in advance
so the ideal thats in now would not have needed the h2 panel or thermal store ?
Reply to the thread, titled "Boiler change" which is posted in Boiler Advice Forum on Plumbers Forums.
