View the thread, titled "Boiler Choice" which is posted in Boiler Advice Forum on UK Plumbers Forums.
H
hamish72
Vented system requires new Boiler
I expect as many opinions as replies 🙂 so what make and model (18 K ) to use existing Y plan external controls would you personally recommend or fit for your own ?🙂
have started installing viesmann's, they are reasonably priced and also have 5 years parts and labour guarentee if installed by certified installer. And also 10year guarentee on heat exchanger. Would be looking at a vitodens 100-W
that or worcester Ri
cant beat broagg. easy service and fault finding, cheap parts. very impressive boilers
especially the quinta.
Do you know if this has an internal pump ? as some earlier worcester models had
system boilers havr pumps in conventional boilers do not.
thanks just checked that the RI is regular
looks like what I will go for
I thought maybe the Glow worm HXI but that seems to get slagged off a lot ?
Reply to the thread, titled "Boiler Choice" which is posted in Boiler Advice Forum on Plumbers Forums.
