Deleted member 112076
Hi all,
My problem is that my oil-fired boiler cuts out before the hot water has reached the thermostat temperature set on the hot water cylinder. At best I get luke-warm water.
I have a vented system and the heating side of the system looks like it is working fine. However, with the boiler set to push out 70 degrees C and the thermostat on the hot water cylinder set at 65 degrees C the boiler shuts down before the hot water has even reached a luke warm level. The immersion heater is doing the job at the moment.
At first, of course, I suspected the thermostat on the hot water cylinder but the Danfos heating/hot water controller is demanding heat and the hot water zone valve is open ('B' position) so I guess that the thermostat is not at fault(?).
Any ideas?
Jack
Any ideas?
Jack
