View the thread, titled "boiler fires on and off every 20 seconds" which is posted in Boiler Advice Forum on UK Plumbers Forums.
L
lotusse
Hi have and ideal boiler ff30 and it fires on and off every 20 seconds .Is this a problem with over heating . or is the room thermostat not working.
The boiler works a gledhill boilermate 2000 .
Any ideas
Check burner gas pressures not to high
Does it do it from cold or when been on a while and heated up
THE BOILER HAS HAD A NEW PCD . FAN AND PRESSURE SWITCH AS THERE WAS A GASKET THAT FAILED AND MEALTED THESE ITEMS.
tHE PUMPS ARE WORKING OK. iF THE ROOM THERMOSTAT IS NOW AT 15DEG'S ITS OK ANYTHING OVER 19-20 AND IT STARTS. HAS ORDERED A NEW ROOM THERMOSTAT TO CHECK.
NOT SURE IF IT IS A PROBLEM WITH THE BOILERMATE 2000 OR THE BOILER (AS IT FIRES ON AND OFF SO DOES THE PUMP IN THE BOILERMATE 2000 )
THIS WOULDN'T BE A OVERHEATING CUT OFF SWITCH ? THING IT HAS TO BE ON FOR SOME TIME BEFORE IT STARTS.
Reply to the thread, titled "boiler fires on and off every 20 seconds" which is posted in Boiler Advice Forum on Plumbers Forums.
