View the thread, titled "Boiler help!!!" which is posted in Boiler Advice Forum on UK Plumbers Forums.
plumbkool
Hi guys ,my son has a brittony 100 se combi boiler, and when you turn on hot water tap the boiler doesn,t fire every time, perhaps one in ten attempts .
We get hot water through eventually if heating is on as well,
The flow switch plunger was not reaching the micro switch to fire the boiler, so I renewed the diaphragm and operating rod ,the diaphragm showed no sign of damage, but the fault persists.
Any clues would be appreciated,
Cheers Ash
Unless your gas safe reg I'm sorry to say you can't take the cover off / try and fix it yourself
And you require a gas safe engy
Reply to the thread, titled "Boiler help!!!" which is posted in Boiler Advice Forum on Plumbers Forums.
