View the thread, titled "boiler job" which is posted in Boiler Advice Forum on UK Plumbers Forums.
T
tiling spread
(Im not gas safe)
Iv been asked by a mate of mine if i can help on a full fit out.
run pipe work hang rads hang boiler (fit the boiler on the wall and run all pipes to it)
fit pipe work for tank tale's for Wc bath sink and kitchen.
first time iv done any plumbing for him as im his main plasterer. (let it slip i can do plumbing):6:
were do i stand on fitting boiler (not fitting the gas) ( but running the pipe work)
and tank
im confident in running pipes hanging rads and coreing out i can fit full bath rooms/kitchens ect
Technically the RGI should hang boiler, run gas, fit flue and commission. You can do water side.
nothing to stop you running pipework to boiler i.e. flow and return hot & cold. regards gas you can run pipe to gas meter but say leave 800mm short.for g.s. plumber to connect and test for tightness. but you would have to know that you've sized your gas pipe correctly again gas safe plumber would calculate this. cheers grant.
I was reliably informed by an inspector that even the wet connections to a boiler are classed as gas work
You shouldnt be doing anything around boiler
Pipe runs and rads are ok. But not gas run. Or within 1m of the wet side on a boiler
I got called out to do a gas cert for one off my landlords , she had gave the builder the whole building project Inc heating & boiler ,
I turned up not noing he got the job ,
I looked at the job , condemned the gas run ( masive leak ) sniffer said leak under new laminate flooring , needs ripping up again to repair , no pipe sleve , flue to long , prv straight pipe , condense flexy out side ( biasi ) , also told landlord I take boiler off wall to double check fixings , earth bonding missing , hob gas cock missing ,, typical builder , they think they no everything , gave landlord big bill to put right
Did you RIDDOR?
i dont touch gas unless
im working for a gs plumber al i do is trv's rads run pipes gas line ect but he is teaching me too most the time im looking and doing what ever he wants
if i dont know i ask he gets the hump some times with me asking but how am i ment to lern if i dont know
It was a mad half hour when I had landlord in one ear , builder in the other ,
I just stared altering the faults , the gas was not turned on , capped by transco at the time ,
The landlord gives me work often , so I thought I just do the works,to teach land lord a lesson ,
Brain not working at the time , only thought about riddor during the repairs
You mention GAS RUN ..!
You can hang the boiler, run the gas run, connect the flue, etc.
Only if you have a suitable Gas Safe registered engineer directly supervising you. This is no different to being an apprentice.
Is this what you are proposing to do?
just go college first learn it all and than go and work with GSR plumber and it will be much easier as everything he says will make sense to you !
you should not be touching the gas pipe, or touching the boiler imho, is your friend gas safe ? why isnt he doin the boiler ? if i had someone helping me who wasnt qualified or experienced enough i wouldnt be having him do the boiler for me, id be having him hanging rads and thats it.
Reply to the thread, titled "boiler job" which is posted in Boiler Advice Forum on Plumbers Forums.
