C
CAROLE-D
I am new on here today and hope someone can advise me.
I have a Worcester 240 RSF combination boiler, Had it installed in 1993.
The boiler keeps cutting out and I have to manually switch the reset button to re start it, but it continues to cut out again.
It can happen every ten minutes or can stay on for hours.
It can also restart by itself - but only sometimes.
It also sometimes cuts out when I am running hot water.....so have to run up the stairs or jump out of the shower (8 times yesterday), to press the reset button again.!!!!!!
I had it serviced yesterday and the engineer said it was the fan.
He removed the cover and showed me....
When it does start up, it groans a lot and the fan is struggling to get started.
I have just sprayed the fan with a little bit of WD40 and now, on start up....it kicked in straight away and started spinning fast, as normal.
However, it is still cutting out....so I am thinking it is not the fan ???
Once it gets going the noise settles down...but it is not long before the noise starts again and gets worse.....groaning, then a clicking noise starts and it cuts out.
Have looked at the manual - problem solving and it suggests that it may be the sequence board....but I cant find a sequece board on the itemised list of parts....it does refer to a "Driver Board"....is this the same thing?...
Also, on checking out the Worcester web site for spare parts for this model, refers to circuit boards and control boards......soooooooo confused with all this and would really appreciate some advice please.
Carole
Carole
