F
FrankHarrington
Hi guys,
This is my first post and I'm only recently qualified so... A customer called me to look at their boiler because it is kettling. It is a Potterton kingfisher MF on an s-plan vented system. It is a semi-pumped system, the hw is gravity circulated and ch pumped. It happens intermittently and not until the systems been on for an hour or two. It then starts banging loudly and spitting out the open vent, consequently the overflow also. They had an insurance cover on their ch (don't think bg it was another) and they sent a couple of engineers out who replaced the pump, checked the boiler stat (apparently) and suggested the feed pipe was blocked or the system needs flushing. Im reluctant to carry out an expensive power flush as the system heats up normally, there are no cold rads and the hw works fine. I don't know if its a red herring but the boiler stat sometimes cuts in and out rapidly, although like i said they apparently checked the stat.
Any help much appreciated!!
Frank
Harringtons Heating and Plumbing
Frank
